Help: Viewing Ram Speed at Post..on MSI K7T Pro
pudcox
235
I am trying do discern whether or not my mobo is running my PC 133 Ram at 100 or 133 ...quick facts: How can I do this?
--i am using award bios 1.7 on MSI K7T Pro
--under advanced chipset options in bios it has option for sdram to be set at host cpu clk + 33M (or something very close to that), but currently it is set to autodetect the cpu clock...which with my 700Mhz T'bird (non Oc) is 100mhz ..right?!?
--so...does this mean my Ram is only running at 100 or how can I check to see what it is running at...I have not seen any info on it during the post at boot
I yield the floor to those more knowledgable than I :) thnx in advance for your help...
Mem
21,476
13
If you set the HST CLK+33 to enable you will be running your ram at 133MHz,the other (default) option is 100mhz.
pudcox
235
thnx..i figured that would be right...but i just like to double check my six on these things..muchas gracias amigo
