- Feb 24, 2003
- 204
- 0
- 0
okall of the sudden I started having this problem link on my computer running a
AIW 9700 Pro, AMD XP2100+ o/c 180x10, A7N8X-DLX, 512MB PC2700 Kingston
I tried it running on another computer it worked fine, I tried running a Ti4200 onthis computer and worked fine aswell, so I RMAed the videocard and I received an AIW 9800 Pro, but the problem is still there.
here are some stuffs that I already tried:
-run videocard on a different monitor
-run another videocard on the computer
-reformatted the computer
-lowered the voltage on videocard and CPU
-set FSB to defauly 166
-disable fastwrite
-disable AGP 8x
im guessing the problem is with the DVI as both ati were DVI and I was having problem only with them.
-disable fastwrite
-disable AGP 8x
