(this is also posted in Technical Support and General Hardware... dunno if Video is the right forum but...)
I took a friend's old Compaq FP700 15" LCD monitor and also bought a Pine Excalibur GeForce2 Ti video card with both VGA and DVI inputs... for what I 'thought' was a DVI connector on the LCD monitor. THEN I discovered the LCD monitor used an old digital connection/interface called "DFP," not DVI. So I bought a DFP to DVI adapter that made the monitor compatible with the DVI input on the video card.
Now, when I start the system, the boot screens appear on the LCD, but AFTER the first WinXP spalsh screen (with the moving/scrolling dots below the logo) and just BEFORE the blue "welcome" screen for WinXP, the LCD screen goes blank!! At that point, If I plug in another monitor with a VGA connection, WinXP shows up on the VGA monitor and I can navigate display properties to switch back to the LCD monitor!! At that point, I can also unplug the VGA monitor and the LCD monitor will continue working properly.
It gets wierder... If I keep both monitors plugged in when I start the system, the boot screens show up on the VGA monitor... but then after the first WinXP splash screen it switches and displays properly on the LCD monitor! Although this makes the LCD monitor work, I would hate to always keep a VGA monitor plugged in just so I can use the LCD. **** The VGA monitor doesn't even need to be on and doesn't even need to be plugged in to a power outlet for the LCD monitor to work in XP!! (The LCD monitor still won't show the boot screens though, but I don't mind that too much.)
btw, there is no dual monitor support on the video card. Also, I tried plugging in only a VGA cord into the video card... doesn't work... the LCD shows boot screens and blanks before entering XP.
So I'm confused... is this a problem with:
1. the monitor (maybe since it's native connection is DFP
2. the video card
3. WinXP
I would really appreciate if anyone can give me feedback, I've spent considerable time figuring this stuff out and it would suck to end like this. Or does anyone know who I can ask? Or... does anyone know why an unpowered monitor plugged into the VGA port will act as a hack solution, and how do I replicate that VGA connection without a huge monitor? (like I said, I already tried plugging in just a VGA cable) My friend said that maybe the VGA monitor has a closed circuit or even a battery inside that makes the video card aware of a connection.
Help? Suggestions? Thanks!
-Derrick
dvan@uclink.berkeley.edu
2. the video card
3. WinXP
-Derrick
