Help Using Tomato Firmware to Connect Xbox Wirelessly
RobDMB
I currently have a BUffalo router that I have flashed tomato onto and plan on ordering a second router to do the same. I would like to set up the second router to act as a bridge for the xbox since its cheaper than buying the wireless adapter. I was wondering if anyone could describe to me how I would set that up using the Tomato firmware? Thanks, Rob
I'm not personally familiar with the Tomato firmware, but I am familiar with DD-WRT Thibor. The two are similar.
There should be an option in the firmware to switch to "client mode", in which the router will act as a wireless client, and will bridge the wireless to ethernet. I've done this before - it's very simple and usually works quite well.
~Misfit
