Help using TI-89?
RESmonkey
4,818
I put this in the calc:
solve( x/y=5.6E-10 and x/z=2.2E-11 and x^2/(y*z)=1E-14, {x,y,z})
and get "false."
WTF? I want to find x y and z.
Safeway
12,075
11
Look in your user manual! Not sure if you need the {} around the x, y, z.
Also, you might have the equation wrong and no such answer exists.
dighn
22,820
4
that system doesn't seem to have a solution. try it by hand and you'll see.
RESmonkey
4,818
Argh. It's actually a chem problem I don't understand, and I'm trying to turn it into a few equations that are easier to look at. If anyone remembers equilibrium constant stuff, I'll post the problem here.
TuxDave
10,571
and get "false."
Um.. it doesn't have a solution the way you have it.
enwar3
1,086
can't solve systems of equations i thought
in any case, false means there is no solution
PottedMeat
12,363
475
Uh I'd say understand the chemistry first than convert it to a strange set of simultaneous equations.
thesurge
1,745
and get "false."
Easy.
Multiply first equation by second equation---> you don't get 1E-14.
RESmonkey
4,818
Kw = Ka x Kb, but using the data given, it doesn't come out to 1E-14. Heh. It's the only question I don't get.
dighn
22,820
4
that's a bit cryptic eh? couldn't they just print "no solution"?
