Help - USB/K8NE Deluxe and Antec Sonata Case
wesy
I just built my system - K8NE Deluxe with the Antec Sonata Case, however, the front panel USB ports won't work. I used the plug that comes from the front of the case to USB Header 56 and the front the USB ports won't work, if I put the plug to header USB 78, the rear panel and the front panel ports don't work? any suggestions? I went to the ASUS site and downloaded drivers/utilities for whatever reason my ASUS CD that came with the MB couldn't be read in my drive, of course everyother cd works! Is there a USB 2.0 driver that I need to install for the MB? I already installed WinXP Pro SP2 on the box. Any help would be appreciated. Other than that this thing screams:
K8NE Deluxe
Athlon 64 3000
Seagate Barracuda 160
Plextor PX-712A
Ati Radeon 9600XT
Antec Sonata Case
Had the same problem more than once! It seems like the USB plugs of many, if not most, cases are wired WRONG. If you look at the plug going from the case to your MB, assuming it is a modular one, I think you will find that PIN 10 has a wire to it. Probably a BLACK wire. If you clip this wire, or if you have individual pin plugs to the USB header, remove the one to PIN 10 and your problem will be solved. It is a mystery how so many cases are wired like this! That wire is usually a ground and is not only not needed but will disable that USB port and probably any other MB USB ports.
Pin 10 is usually labeled in the USB specs as "over current". It was either never implimented or not supported by MB makers.
Let me know if this helped, it took me forever to figure it out and I have used it many times.
wow - well done cardio. - i had that prob on a few systems. took front casing off - traced wires.
In the end gave up and apologised.............
Motherboard manfacturers all approach USB headers differently, but with the same results.
With your motherboard\case combo, the wiring should be as follows:
Pins (bottom row)
1 - +5V
3 - D-
5 - D+
7 - GND
Pins (upper row)
2 - +5V
4 - D-
6 - D+
8 - GND
10 - NC
I know this is probably a "well DUH" question, but you made sure it was the USB cable and not the Firewire cable, quiaff? 😀
I saw your fix for the USB issue wesy was having - I have been looking for a solution for my own front port USB problem. I have an A7N8X-E Deluxe board - not sure what kind of case it is but I would guess Antec or Lian Li. Anyway, the USB cabling had all the separate pin outs - I finally got them hooked up right just as LiLith TecH said later in the thread:
Pins (bottom row) Pins (upper row)
1 - +5V 2 - +5V
3 - D- 4 - D-
5 - D+ 6 - D+
7 - GND 8 - GND
10 - NC
The problem I have is that the front USB ports would only pick up my USB 2.0 fujifilm jump drive when the bios was set to 1.1. If I set it to 1.1/2.0, I get an "unknown device" in my device manager under USB controllers. I even went as far as replacing the internal header cable thinking that it might have been the quality of the wiring/shielding. These were not the single pin out type so it was easier to hook up but in the end I still got the same result. All the other USB ports in the back pick up the jump drive just fine as a 2.0 device. I've also updated my bios, searched for drivers and so far nothing has fixed the problem. Never have I lost the use of all my USB ports - just can't run 2.0 on the fronts. I'm running XP Pro sp2. Any ideas?
wolfiethaman
To make sure they are connected correctly, the order of the colored wires should be:
Red(5V) - White(D-) - Green(D+) - Black(Gnd)
Not all aftermarket USB Cable assemblies are created equal.
Thanks for the reply - I have matched things up properly on the mb but still get same result. I'm looking at the case-side connector and cannot tell what is what for pin assignments aside from which bank is 1 or 2. Might that be the problem?
I would have to say that it's identical to (looks identical except for the Antec badge) the SX1040BII (performance series II SOHO file server).
That's looks just like it but mine's of the 522mm (H) variety but without the window. I browsed Chieftec's site and found this one that looks like a closer match - thanks for getting me there:
DX-01BD-U.
Either way, I think I know where you're going with this. I see that there are links to their USB/1394 connection instructions for two different versions (good to know). I can see v4 but the I can't see v3 - there's something wrong with the PDF file the link is going to. Can you see it? I think mine's v4 though because the pin assigments look the same:
35_USB_v4
Do you happen to know what the difference between versions is though? I got my case off of eBay a while back and never knew what the brand was - not the "case" now 🙂 I'll play around with it and let you know how it works out.
Great, looks like it's going to be a while - my primary hard drive crapped out on me today. My SCSI controller sees it , then it doesn't and it's making some seriously abnormal sounds......dammit. That's timing for you. Thanks LilithTecH, I appreciate your time but this problem is even suckier than my first. I may have to start looking for a new hard drive now.:|:|
Ok - I've gotten my hard drive woes sorted out and am ready to hit the front end USB problem again. I've aligned my header connections according to the intel standard (v4 - still trying to get Chieftec to send me v3 to see if it's any different) and Chieftec's own connection diagrams. Still the same problem - ports will only work as USB 1.1. There is a jumper on the mb right next to the USB header that apparantly changes the voltage from +5 v to +5 smv. Not that changing this setting helped at all, but what is the difference?
Any other suggestions besides maybe replace the case-side USB/1394 connector unit?
The jumper is for USB 5VSB aware devices and requires the PSU to support it.
Setting it to +5VSB will cause the system not to boot if the PSU does not support it.
Essentially is the Serial equivalent to Wake-On-Lan.
