I've decided to upgrade my Alienware with the latest and greatest hardware. I thought about buying a whole new rig from them but decided it would be much cheaper just to upgrade the internal components.
Here is my current setup:
Asus P4C800-E Deluxe mobo
Intel P4 3.2ghz Extreme Edition processor
2x 36gb WD Raptors
2 gb(4x512mb) Corsair XMS Low Latency RAM(3x3x3x8 CAS Latency)
ATI Radeon 9800XT with Artic cooler
Soundblaster Audigy ZS
Alienware 420w PSU
*All factory installed by Alienware- I've been very happy with this rig but feel its time to upgrade since its about two years old now.
Upgrading to:
Asus A8r32 MVP Deluxe
AMD FX-60 Dual Core w/ Zalman CNPS9500 HSF
2x 36gb WD Raptors(keeping from old rig)
250 gb WD Caviar Sata2 w/16MB cache
2 gb(2x1gb) PC-3200 OCZ Platinum Edtion RAM(2.5x2x2x5 CAS Latency)
ATI X1900XT
X-Fi Fatality
Seasonic S-12 600w PSU
Pics: http://i58.photobucket.com/albums/g246/Kerby1280/DSC01030.jpg
Will I be able to migrate my current Raptors to the new mobo? They are currently in RAID-0. I would like to use this as my main hdd with the 250gb Caviar as my data hdd. I would also like to keep all my current data on it when moving to the new mobo. Is that possible? I've heard that when you switch RAID controllers you can not do it. Should I just delete everthing on the Raptors and do a fresh install of Win XP on the new mobo?
What other possible conflicts can I expect to run into?
I plan on starting this project this weekend. Any help would be much appreciated. Thanks.
2x 36gb WD Raptors
Alienware 420w PSU
Upgrading to:
ATI X1900XT
X-Fi Fatality
