- Aug 2, 2003
- 278
- 0
- 76
Hi,
Been a while since i've been on AT but I was looking to upgrade my current setup:
cpu: Intel Core2 Quad Q6600 2.4GHz
mobo: Abit IP35-e
RAM: G.SKILL 2x2GB DDR2
HD : 1TB seagate 7200RPM + 3TB seagate 7200RPM
GPU: eVGA 7800GT w/ NV5 Rev. 3
psu: 450W SmartPower
OS: Windows XP 32bit
I had originally built this system in 2005 purely for gaming (with your help), then upgraded the mobo/cpu in 2009 for better video editing.
Over the years my needs have changed, where now I no longer play games on my system, but use it more for general multitasking, playing 1080p movies, serving 1080p movies via PS3 media server/Serviio (sometimes this maxes out my cpu and uses a ton of RAM), excel, and some photo/video editing. Startup takes longer than I would like and the overall responsiveness is not as quick as I would like, even after a clean OS install.
Also, I need to switch to Windows 7 (clean install, home premium 64 bit) since XP's support life is ending.
Some questions:
- Looking at my system and my needs, can my system handle Win7? All else equal, will Win7 be more or less responsive than XP for the same hardware?
- How much benefit would I get buying a SSD for my boot drive? Is that the best bang for buck in terms of general responsiveness?
- How can I tell if adding more RAM would help?
- Any obvious bottlenecks in my setup?
At first I was thinking of going all out with new i5 CPU/mobo, 8gb of DDR3 RAM, win7 and SSD, but that would cost >$700 and seemed overkill for my needs.
thanks.
mobo: Abit IP35-e
Some questions:
thanks.
