These are the parts I got:
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
http://www.newegg.com/Product/Produc...82E16820231428
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost)
http://www.newegg.com/Product/Produc...82E16819115072
ASrock Gen3 Z68 Extreme3 mobo
http://www.newegg.com/Product/Produc...82E16813157271
XFX Radeon 6950 HD Dual Fan
http://www.newegg.com/Product/Produc...82E16814150549
Basically I upgraded from an older build, but I kept the same PSU and case. PSU is OCZ Gamestream 600W.
So I followed the motherboard guide and New Egg computer building video tutorial, starting with mounting the motherboard, added I/O shield, (used 7 mobo mounting screws, made sure none of them were unaccounted for/touching the underside of the motherboard, used 7 screws to screw the motherboard into the mounts, and not too tight). Then I put the CPU & heatsink in, which went fine. Then went RAM and video card. Video card was a bit difficult to fit due to size but with enough of a hassle it fit.
Then came SATA/power SATA cables from the PSU, USB plugs, power button and LEDs, and all other necessary power cables needed for the mobo, graphics card, and fans.
When I was ready, I plugged in the power cable, video cable, USB mouse and keyboard, and audio plugs, and hit the PSU switch on the back. Almost immediately I smelled a burning smell. After 2-3 seconds I immediately switched it off and unplugged the power cable. A friend came over and took a look himself, took out the RAM to smell it but there was no burning smell. And there's no visible imperfections on the mobo or anything else for that matter. I unplugged all PSU cables and turned the PSU on to test it, and there was no burning smell.
What could be the issue here? Have I shorted the motherboard? I seriously don't understand how, as I checked everything and followed the mobo manual closely...
I'm too paranoid to turn anything on again, so I will be waiting for my friend's father to help me out either Friday or Saturday. I would just like some input and suggestions. Does a burning smell mean I just flushed $640 down the drain? I seriously hope not. I'm not a stranger to building PCs. This is my 3rd upgrade. I appreciate any advice/help. Thanks.
EDIT: Also want to mention that I did not notice an LED turn on on the mobo, but then again I didn't have time to notice because as soon as I smelled something I immediately turned it off and unplugged.
