Help tweaking my laptop
NoxPT
41
ok this is a bit hard to explain. I have a toshiba satellite laptop with windows XP home edition on it. when you first turn it on it brings up a toshiba boot up screen then the xp screen. I have already modified the XP boot up screen and login screen but I can't kill the toshiba screen. if you have any suggestions please let me know.
minendo
35,560
22
Look through your BIOS, but it is probably unable to be removed.
Zim Hosein
Super Moderator | Elite Member
65,430
408
NoxPT, if I'm not mistaken, the "Toshiba" boot-up screen is embetted in the BIOS.
edit: I've been beat to the reply by minendo.
minendo
35,560
22
NoxPT, if I'm not mistaken, the "Toshiba: boot-up scren is embetted in the BIOS.
You are correct. The only way to remove it is to find a BIOS flash that does not contain that screen programmed in. Well unless there is an option to remove it in the BIOS.
NoxPT
41
ok next question, is there any way to access the bios without restarting the computer?
Scarpozzi
26,392
1,780
I'd probably just live with it if I were you. The motherboard on that laptop was probably created specifically for Toshiba so if you flash it with the bios manufacturer's firmware updates some things may not work correctly anymore. ;)
Yeah....you have to restart the computer to access it.
SyahM
1,788
talking about Toshiba laptop, today at COMPUSA i tested the new Portege 3505 Tablet PC, boy, that thing is sweettt!!!
NoxPT
41
ummmm syahM that doesn't help me one bit, thanx for the in put if I decided to get a new one, but still...
