Help! Turning on Mobo without power switch
LIVAN
Hi there,
I am doing a quick test of CPU,Ram, Video and Mobo. I just need to see if it posts.. I Hooked things up and realized that I didn't have a Case with the little pin that we usually to power up a system. Is there anything I can do here? Like hot wiring the board or something?
Originally posted by: LIVAN
Hi there,
Yeah, use your mobo's owners' manual to identify which pins the case's power switch wire would plug into, then do like shown here: photo The screwdriver tip makes a momentary electrical connection between the pins, same as the case's power button would do, and the mobo will then fire up the PSU.
