I picked up this motherboard with a bunch of parts in it (P3-500, SB Live, ethernet), and just added a Seagate 7200.7 120gb to the mix. After installing WinXP SP1, the computer won't boot into windows - BIOS is fine.
I took everything out, reformatted the HD with an NTFS 20gb partition using the WinXP recover menu, and the system only has videocard, ram, CPU and PSU.
Same problem occurs - I'm able to go through WinXP copying files blue-screen setup, but on first boot from HD (to setup), the computer either
1) reboots automatically
2) gives a blue screen of death
3) just stalls with a black screen
Any clues? BIOS says something like version Nov. 1999. I've tried swapping out video card, ram, and PSU - basically having everything different except motherboard and CPU. Is there something I'm missing here?
