help troubleshooting NMI Parity Check error
roid450
858
I've been getting BSOD with that error message on it, and nothing more. Also i get some with nothing at all except **The system Has Halted**
My CPU is OCd to 3 ghz (9X333.3) and I have ran prime 95 a few times, once letting it go to about 18 hrs with no errors on Blend and once on Large FFT. I also have OCCT and have ran 2 hr Ram checks and everything says OK.
I have only gotten the BSOD while surfing the net and twice while I started to load GRID and once when I double clicked on Everest, it just Blue Screened.
I'm sorta out of ideas as to what it could be. I haven't gotten BSOD while gaming, I played Crysis for about 6 hrs saturday and computer was good all weekend.
:confused: stats are in my sig. The memory is running stock clocks and at 2.0V 5-5-5-15. My DRAM/FSB Ratio is 8:5 and the Multiplier for my CPU is locked to 9 and 6
mpilchfamily
3,559
First thing you need to do is rule out the OC. So take the system back to stock and see what happens. If your still having problems then run Memtest to see if the RAM is what's going bad.
