yea what im asking for help with is how to get the cc_config to work. people keep saying "in your boinc data directory" but apparently that isnt specific enough, since BOINC isn't finding the file in the default location, or if i put the file in the boinc programdata folder (separate from the install folder). how do i know when it's reading properly and where the hell exactly do i put it. i've been asking this same question across 2 forums so far and no one's giving me a direct answer except repeatedly telling me what i already know. ive followed all of the basic instructions and intuition in trying to set it up from the links provided but so far i haven't been able to figure out how to get BOINC to even recognize the file and register to me that it's loaded said config. Yes, my cards are showing up as disabled, yes i know about the monitor trick and right now it doesn't matter anyway because as i already stated, i've spent a lot of time troubleshooting this and i'm not moving forward until someone can help me explain why the config file wont load properly.
now, from http://boinc.berkeley.edu/wiki/Client_configuration, im making an XML file with the only contents being
<cc_config>
<log_flags>
<use_all_gpus>1</use_all_gpus>
</log_flags>
</cc_config>
this file is going in C:/program files/boinc or equal directory. So far after placing it in the directory this is how far i have gotten, i have not been able to get it to tell me in the log that it's successfully read the config or to get it to use all 3 cards at once with the latest BOINC. i have restarted my computer and restarted BOINC, and whenever im trying to get it to work in 7.0.64 im obviously using a fresh install of BOINC.
<cc_config>
<log_flags>
</log_flags>
</cc_config>
