NetWareHead
THAT guy
Wondering if you guys can help with this set of symptoms please?
Honda HS55 snowblower with commercial quality Honda GX engine.
The engine starts normally with fuel open and choke closed. As engine warms up, I gradually move the choke more and more to the fully open position.
The issue is when the choke is fully opened, the engine begins to run rough. Rough as in the sense that it runs in "fast cycles" as if it were slowing down and then speeding back up. It sounds to me like when an engine is running out of gasoline and not at a consistent sound or rpm. (Not sure if describing this properly)
At first, I thought the engine just wasnt warm enough so I left the choke at half position and gave it a few more minutes. Even after letting the engine warm up for more than 5 minutes additional time, when I moved the choke to fully open, the fast cycle of rough running returns.
I can get the fast cycling to go away if I refrain from opening the choke fully. Actually the engine runs perfectly and has a consistent sound and rpm when the choke is open at I estimate 75% position.
My theory based on my limited knowledge of engines:
Choke closed provides engine with a rich mixture so it can start more easily. As engine warms up, rich mixture not needed and choke can be opened (allowing more air and creating less rich mixture). My theory is when choke is fully opened, the engine is perhaps receiving too much air and creating a lean mixture. IMO, this is why it sounds the best with choke 75% open as this creates the correct fuel mixtures.
It also sounds like shop that did previous work never adjusted the carb accurately. So should I be looking for ways to correct this overly lean condition? Anything to watch out for (keep me from messing up my engine)?
Can you see anything wrong with running engine under load (snowblowing) with choke set at 75% position?
