- Mar 7, 2009
- 13
- 0
- 0
Help, I cannot seem to get my new system to work. I read Anandtech all the time, but this is my first system build.
I am trying to build the AnandTech Intel Budget system. Here are the specs:
Motherboard: Gigabyte GA-EP45-UD3P(rev. 1.1)
Video Card: Gigabyte GV-R455D3-512MB
CPU: Intel E7300 w/Intel heat sink
Memory: G-Skill 2x2048 8500
PowerSupply: Corsair 400W
generic SATA DVD writer
2x500GB generic SATA HDD
Antec 300 case
When I assemble everything, turn it on, nothing happens at all-- no CPU fan, nothing. If I take the 24-pin power supply, short the 4- and 5-pins (paper-clip connecting those two), but leave everything else plugged in, everything not powered through the MB turns on-- the case fans, the HDDs spins, the DVD spins, etc.
I dissassembled everything, including the MB from the case, and had just the CPU and CPU fan (not even memory or video card) plugged in, and nothing happens when I power up, at all. (I had the 24-pin and the 8-pin power connectors connected.)
I assumed the MB was bad, so I sent the MB back (NewEgg) and got a replacement. I repeated the whole process, and, again, nothing turns on at all when I power up, but when I power everything up w/o the MB, it turns on.
Obviously, this can't also be the MB. What am I doing wrong?
I triple-checked all of the pin-outs on the MB manual and the power-supply manuals; they all agree.
I don't simply have a 2nd CPU "lying around" or a 2-nd set of memory lying around, or a 2nd video card lying around, so I can't just start swapping out various components.
Without a 2nd component of everything lying around to test, should I just return everything and buy an HP or other box?
Help
