help to choose 19': IIyama Vision master pro 454 vs. Samsung 959NF
zulu555
Now Here is specs for IIYAMA 454:
Model HM903DT
Vision Master Pro454
CRT 49cm, 19" (18", 46cm viewable)
Flat Screen High Brightness
DiamondTron M2-CRT
Dot pitch 0,25/0,27mm AG Pitch
Aperture Grille
Sync frequency Horizontal: 30 - 130kHz,
Vertical: 50 - 200Hz
Video bandwidth 345MHz dot clock
Resolution 0640 x 0480 @ 200Hz refresh
0800 x 0600 @ 200Hz refresh
1024 x 0768 @ 160Hz refresh
1152 x 0864 @ 142Hz refresh
1280 x 1024 @ 121Hz refresh
1600 x 1200 @ 104Hz refresh
1800 x 1440 @ 087Hz refresh
Input connectors 2 x 15 pin D-sub connector, Audio,
USB upstream / 4 x downstream,
Headphone connector ø 3.5mm
mini jack
Plug & Play VESA DDC 2BTM Compliance
Number of Factory-presets: 6
signal storage User memory locations: 10
Dimensions 450mm x 450mm x 447mm (WxHxD)
Net weight 24kg
and SAMSUNG 959NF
959NF Specs:
640 x 480 / 160 Hz
800 x 600 / 160 Hz
1024 x 768 / 132 Hz
1152 x 864 / 118 Hz
1280 x 1024 / 101 Hz
1600 x 1200 / 87 Hz
1792 x 1344 / 78 Hz
1856 x 1392 / 75 Hz
1800 x 1440 / 73 Hz
1920 x 1440 / 73 Hz
so apperantly they share the same tube' but the refresh rates of IIAMA is better. I don't know about visuaL QUALITY, but TOM'S liked very much the IIyama, and at forums here ppl like Samsung. Iiyama is more expensive (ab. 120$ more) at my country. probably I'm not going to play much at 1600x1200,and @ 1280x1024 the both are decent. so do you justify choosing mo expencive monitor only becouse of hier refresh rates?
