Help this Noob with overclocking a 2180!!
Face2Face
4,100
215
Hi guys, Need some help with overclocking my system. I have
Gigabyte GA965DS3 Rev3.3 motherboard
intel 2180 @ 2Ghz
Thermaltake TMG I1 CPU cooler
2gb (Now 1gb)OCZ platnium PC8500 1066mhz 5-5-5-15
8800gt 256
600watt Ultra PS
I had one of the memory sticks fail on me, and i am going to rma it for a new one.
I want to achieve 3-3.2 GHz, I am new to this old motherboard and new to intel. Since i have factory overclocked ram, i would like to take advantage of it. What do you guys think?
Also what is this System memory multi in bios 2.00-4.00 are the options? what kind of voltage to the ram and cpu? i have the core temp, orthos and mem test program already installed. thanks for taking the time to read this.
cubeless
4,295
walk through the guide at the top of this forum... u ought to be able to just set the fsb to 266 for your first stop... the chip ought to do 2.66ghz with no more voltage if it's a 'good' chip... work up from there...
Drsignguy
2,264
+1:thumbsup:
I have a E2160 and as for bios settings, I set them to manual. To whatever your VID is, set it to that in your voltage settings, make sure you set PCI-E to 100mhz. Change your FSB to 266 like "cubeless" has sugested, adjust your ram timings to the default settings, ratio to 1:1 and reboot. There is your "quick" start. These chips are pretty easy oc'ers and you shouldn't have much difficulty getting it to 3.2 - 3.4 + with your HS. Do stress tests and enjoy! :)
VirtualLarry
56,587
10,225
I have two rigs with E2140s installed, running at 1.41875v (BIOS), in GA-P35-DS3R v1.0, F9 BIOS, at 400 x 8. I have Patriot 2x2GB DDR2-800 5-5-5-12, running at DDR2-800 5-5-5-15 1.8v.
Even though you have fast RAM, it really doesn't help much to run it faster than 1:1. IOW, the gains are mostly only theoretical in nature.
I suggest trying for (eventually) 400 x 8, as that maxes out the FSB pretty well and the RAM pretty well. I don't see any benefit to faster RAM, you may feel differently.
Face2Face
4,100
215
how do you set the memory ratio? is that the same thing as SPD 2.00-4.00? i also have my ram running @ standard voltage which is 1.8v i think. I believe OCZ says to run this ram @ 2.1-2.3 v. What are signs to look for when you need to apply more voltage during an overclock?
myocardia
9,291
30
Yes, run your RAM @ the 2.00 multiplier. That's actually the 1:1 ratio on Gigabyte boards. You should definitely give that RAM +.2-.3v of vDimm, unless you keep it @ 1:1. And you'll know you need more vcore when your overclock starts becoming unstable.
Face2Face
4,100
215
I think there is an issue with my ram. Everytime i rasie the FSB the Ram acts up. I am keeping the Ratio @ 1:1, and with such a small overclock it fail memtest after memtest. But in it's stock setting it passes no prob. It is OCZ DDR2 8500 runs @ 1066. But my motherboard only registers it as DDR2 667. I am keeping the voltage @ stock 1.8v with the ratio @ 1:1. I have had the cpu up to 3GHz runnung orthos CPu stress test only and it seems stable @ 1.4v. Maybe my rams sucks or I do! Any input?
VirtualLarry
56,587
10,225
If the RAM requires 2.1v or more, then give it to it. That's probably your problem. Adjust VDIMM to +0.3v, and re-test (with a Memtest86+ bootable CD).
