HELP!!! Technical Stuff
Dankid
Hi You All,
I need a favor. I just hit my motherboard with a screwdriver while installing the CPU Heat Sink Fan.
I have Soyo K7V Dragon.
I think I may cut one of the etching line (current line).
Now, the motherboard only give long beep.
According to the manual, it must be RAM problem.
I tested the RAM on Bank 1,2, and 3. Still wont work.
So, could anyone please tell me how to fix the cutted current line?
I heard there's a conductance pen to fix this.
But, I could not find any single pen on the web.
Thanks a bunch.
DS
:Q
can you try the memory in another comp ?
also you didn't say if the comp was shutting down right away or not
if so then you need to have a 3wire fan pluged into fan header #1 or comp will shut it's self down
good luck
