A little window comes up and says Task Moniter has perform an illegal operation and will be shiut down. And when i clikc Details it says its something 2 do with Kernel32 or something??
Ooo see i thought u couldnt disable TaskMon or it would fvck up ur computer when it started up... whut all do u ahve 2 have 2 make windows 98 run right when u start up?
