Hi,
I just bought Epox 8RGA and t-bred B 1700+ with the expectation to run it at high multiplier.
I heard n-force2 boards unlock all multipliers??? not true.
It turns out that I can only set multiplier at 12.5x maximum.
The 13x and above multipliers are locked (no post and return to the low speed setting.
Is there an easy way to unlock those multipliers?
I have Kingston PC2100 RAM which will not go pass 150 FSB. I know that the CPU
still have not reach its limit with this 150*12.5
Thanks in advance.
Update:
Nevermind. I found an option to divide FSB to the RAM Frequency. So.. my problem was solved. Great MB.
Thanks in advance.
Update:
