new build has random crash problem,
windows erro code:
Error message: STOP 0x000000EA THREAD_STUCK_IN_DEVICE_DRIVER
View products that this article applies to.
Article ID : 293078
Last Review : July 13, 2005
Revision : 3.6
This article was previously published under Q293078
SYMPTOMS
You may receive one of the following Stop error messages:
STOP: 0x100000EA THREAD_STUCK_IN_DEVICE_DRIVER_M
CAUSE
This issue may occur if the display driver is caught in an infinite loop while it waits for the video hardware to become idle. This issue typically indicates a problem with the video hardware or that the display driver cannot program the hardware correctly.
RESOLUTION
To resolve this issue, obtain and install the most current driver for your video adapter, or replace your video card.
WORKAROUND
To work around this issue, follow these steps: 1. Click Start, click Control Panel, and then double-click Display.
2. On the Settings tab, click Advanced, and then click the Troubleshoot tab.
3. Move the Hardware Acceleration slider to None, and then click to clear the Enable Write Combining check box.
4. Click OK, and then click OK.
Note This procedure prevents the display driver from programming the hardware incorrectly, but you may lose some display functionality and performance. Although you can increase the hardware acceleration settings higher than None to regain functionality and performance, these settings increase the chance that the issue will occur again. For maximum stability, leave hardware acceleration off.
MORE INFORMATION
This Stop error message may also occur in video adapter drivers that do not represent a physical device. For example, this Stop error message may occur in the virtual video adapter driver that is used by Symantec PCAnywhere. If PCAnywhere is installed on a computer where this error message occurs, visit the Symantec Web site to determine if there are any available fixes for your version of PCAnywhere.
The third-party products that this article discusses are manufactured by companies that are independent of Microsoft. Microsoft makes no warranty, implied or otherwise, regarding the performance or reliability of these products.
APPLIES TO
? Microsoft Windows XP Professional
? Microsoft Windows XP Home Edition
? Microsoft Windows XP Professional for Itanium-based systems
Back to the top
Keywords: kberrmsg kbhardware kbenv kbprb kbacwsurvey KB293078
My driver version is 78.01 and I tried to flash system bios, no success
Any suggestions?
Thanks!
windows erro code:
Article ID : 293078
Revision : 3.6
SYMPTOMS
CAUSE
RESOLUTION
WORKAROUND
MORE INFORMATION
APPLIES TO
Back to the top
Any suggestions?
Thanks!
