Hi there!
I am setting up a system for a friend with the above motherboard and a Mitsumi (I think) floppy drive.
Here's what's going on:
I plug the cable into the motherboard (connector is keyed so it only goes in one way - Pin1 is on the bottom as diagrammed on the mobo)
Plug the last connector into the floppy drive (after x-over)
Power on
One of the following two things happens:
1) Floppy drive light stays on all the time (connector flipped)
2) POST code reader says "FF", hard drive light is on, CD-ROM drive is on, no signal out of the video card, system doesn't reset - must hold down the power button to power it down.
However, if I plug the MIDDLE connector into the floppy drive, it WORKS. Does anyone know why the 8K7A doesn't like a crossed-over floppy connector? Or is my floppy drive screwy?
Thanks,
Alex
Power on
Thanks,
Alex
