Help! Stopguard.com spyware killing my IE
UncleWai
5,701
68
I went to HK for two months, so I let my mother to use the computer.
When I come back, the computer is filled with spyware.
I used spybot to clean up most of the junk, but those stopguard.com popup is still coming up.
Also the IE is very slow and laggy.
What can I do to get rid of the stopguard spyware?
*updated*
When I tried to delete the registry of O4 - HKLM\..\RunOnce: [*tcppc] C:\WINDOWS\java\tcppc.exe rerun
tcppc.exe will instantly add the registry back.
tcppc.exe itself is hidden, even when I chose view all hidden files.
I had to use a program called Process Explorer (which work similar to windows task manager).
I needed to suspend the action of tcppc.exe, then used hijackthis to get rid of the registry.
I hope if there are people that are having similar problems, they can use this method to fix it.
UncleWai
5,701
68
Here's the log, I found this to be the spyware
I chose show hidden files, but somehow I still can't see the file existed.
I tried to create a file with the same filename, but windows said it's already existed.
Hijackthis couldn't delete O4 - HKLM\..\RunOnce: [*tcppc] C:\WINDOWS\java\tcppc.exe rerun
what can i do now?
Logfile of HijackThis v1.98.2
Scan saved at 9:01:55 PM, on 9/7/2004
Platform: Windows XP SP1 (WinNT 5.01.2600)
MSIE: Internet Explorer v6.00 SP1 (6.00.2800.1106)
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\svchost.exe
C:\WINDOWS\System32\svchost.exe
C:\Program Files\TGTSoft\StyleXP\StyleXPService.exe
C:\WINDOWS\Explorer.EXE
C:\WINDOWS\system32\spoolsv.exe
C:\PROGRA~1\LEXMAR~1\ACMonitor_X84-X85.exe
C:\PROGRA~1\LEXMAR~1\AcBtnMgr_X84-X85.exe
C:\WINDOWS\System32\spool\DRIVERS\W32X86\3\printray.exe
C:\Program Files\Audio Deck\EnMixCPL.exe
C:\Program Files\WinFast\WFTVFM\WFWIZ.exe
C:\WINDOWS\System32\Ati2evxx.exe
C:\Program Files\iPod\bin\iPodService.exe
C:\Program Files\Miranda IM\miranda32.exe
C:\Program Files\Netscape\Communicator\Program\netscape.exe
C:\Program Files\WinFast\WFTVFM\WFTV.exe
E:\Applications\PM6\PM6C.EXE
C:\Program Files\nbpro\nbpro.exe
C:\Program Files\foobar2000\foobar2000.exe
C:\WINDOWS\System32\conime.exe
C:\Program Files\Internet Explorer\iexplore.exe
C:\Documents and Settings\Admin\Desktop\hijack\HijackThis.exe
O2 - BHO: CATLEvents Object - {BF755B85-EA69-4F58-9A59-D85F384A15FF} - C:\DOCUME~1\Admin\LOCALS~1\Temp\cppct.dat
O3 - Toolbar: &Radio - {8E718888-423F-11D2-876E-00A0C9082467} - C:\WINDOWS\System32\msdxm.ocx
O4 - HKLM\..\Run: [IMJPMIG8.1] C:\WINDOWS\IME\imjp8_1\IMJPMIG.EXE /Spoil /RemAdvDef /Migration32
O4 - HKLM\..\Run: [PHIME2002ASync] C:\WINDOWS\System32\IME\TINTLGNT\TINTSETP.EXE /SYNC
O4 - HKLM\..\Run: [PHIME2002A] C:\WINDOWS\System32\IME\TINTLGNT\TINTSETP.EXE /IMEName
O4 - HKLM\..\Run: [KernelFaultCheck] %systemroot%\system32\dumprep 0 -k
O4 - HKLM\..\Run: [Lexmark X84-X85 Button Monitor] C:\PROGRA~1\LEXMAR~1\ACMonitor_X84-X85.exe
O4 - HKLM\..\Run: [Lexmark X84-X85 Button Manager] C:\PROGRA~1\LEXMAR~1\AcBtnMgr_X84-X85.exe
O4 - HKLM\..\Run: [PrinTray] C:\WINDOWS\System32\spool\DRIVERS\W32X86\3\printray.exe
O4 - HKLM\..\Run: [EnvyHFCPL] C:\Program Files\Audio Deck\EnMixCPL.exe
O4 - HKLM\..\Run: [iTunesHelper] C:\Program Files\iTunes\iTunesHelper.exe
O4 - HKLM\..\Run: [WinFast Schedule] C:\Program Files\WinFast\WFTVFM\WFWIZ.exe
O4 - HKCU\..\Run: [STYLEXP] C:\Program Files\TGTSoft\StyleXP\StyleXP.exe -Hide
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~2\Office10\EXCEL.EXE/3000
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - (no file)
O9 - Extra button: Related - {c95fe080-8f5d-11d2-a20b-00aa003c157a} - C:\WINDOWS\web\related.htm
O9 - Extra 'Tools' menuitem: Show &Related Links - {c95fe080-8f5d-11d2-a20b-00aa003c157a} - C:\WINDOWS\web\related.htm
O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\MSMSGS.EXE
O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\MSMSGS.EXE
O16 - DPF: {166B1BCA-3F9C-11CF-8075-444553540000} (Shockwave ActiveX Control) -
O16 - DPF: {4C39376E-FA9D-4349-BACC-D305C1750EF3} (EPUImageControl Class) - http://tools.ebayimg.com/eps/w...ALControl_v1-0-3-9.cab
O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} (WUWebControl Class) - http://v5.windowsupdate.micros...site.cab?1094363869562
O16 - DPF: {9F1C11AA-197B-4942-BA54-47A8489BB47F} -
O16 - DPF: {A662DA7E-CCB7-4743-B71A-D817F6D575DF} (Autodesk DWF Viewer Control) -
O16 - DPF: {B2BE75F3-9197-11CF-ABF4-08000996E931} -
O16 - DPF: {E855A2D4-987E-4F3B-A51C-64D10A7E2479} (EPSImageControl Class) - http://tools.ebayimg.com/eps/a...x/EPSControl_v1-32.cab
O17 - HKLM\System\CCS\Services\Tcpip\..\{2DE5375F-801A-41C3-A823-3C1470D3DC24}: NameServer = 192.168.0.1
O17 - HKLM\System\CCS\Services\Tcpip\..\{36907E07-E317-4FA9-99A6-72E4E5CD25A0}: NameServer = 192.168.0.1
O17 - HKLM\System\CS1\Services\Tcpip\..\{2DE5375F-801A-41C3-A823-3C1470D3DC24}: NameServer = 192.168.0.1
Schadenfroh
38,416
4
Hello UncleWai,
Before you do anything
1. Make sure that you have extracted HiJackthis to a folder that is isolated before removing anything, for hijackthis makes backups within the folder it is in.
2. Reboot into safe mode
3. Close all browsers/windows explorer
fix the following in hijackthis(kill the process in process viewer, if its there)
  • O2 - BHO: CATLEvents Object - {BF755B85-EA69-4F58-9A59-D85F384A15FF} - C:\DOCUME~1\Admin\LOCALS~1\Temp\cppct.dat
additional steps
  • 1. Delete the file "C:\WINDOWS\java\tcppc.exe"
    2. Clear your temp files using start>run>"cleanmgr"
    3. Restart into normal windows
