HELP! Stop Error message in WinXP Home
Twister00
Has anyone ever seen this error message in WinXP before:
On a blue screen:
Stop: C0000221 Unknown Hard Error
\Systemroot\system32\ ntdll.dll
Or this one?
On a black screen:
Windows could not start because the following file is missing or corrupt
\windows\system32\config\system
This is on a new P4 2.0A with an MSI 845E Max motherboard with 512MB DDR 2100 a Maxtor 30GB 7200 HD with MSI 64MB GeForce 4 MX420 VC
I swapped memory with another stick I know the HD is working properly and did a repeat test and came back in proper working order.
Thanks in advance
Your first message i've never seen before, but, the second one I have. If you've already done restore points in XP then your OK... Just do a system repair. If not, reinstall XP. That's what I had to do because I hadn't setup restore points yet 🙂 *ding*
