I'm using an SSD drive on an older Mobo. I don't expect to get full speed out of it, but I'd like to make sure I'm getting the most I can. I plan to rebuild everything next year, so I'm hoping I can get some quick advice and be on my way.
Primarily what I want to know is: 1) Do I need to flash my mobo bios? and 2) Is there an easy way to check the speed of my SSD to confirm I'm getting the most out of it?
SSD: Samsung SSD 840 Series, 128Gb
Mobo: GA-965p-s3 Revison 1.0
BTW, it says "1.0" etched (in white ink) into the mobo and from memory this sounds right. There's only one other version, 3.3. It's been a while, but I'm pretty sure I had the first version. Can I count on that etched 1.0 or do I need to check more before I do a bios flash?
Assuming I have revision 1.0 of the mainboard, here's the link to the bios page. I generally avoid flashing the bios unless I think I have a good reason to do it. Basically, what I'm looking for is someone to look at the flash updates and see if any of them apply to running an SSD drive. There isn't much to read, but I have no idea what might apply. It's been at least 5+ years since I built this PC and I've lost track of new technology.
I'm be very grateful if someone could take a quick look at this page and let me know if there's anything flashes that might relate to the SSD: I'm currently only at F5 bios.
http://www.gigabyte.com/products/product-page.aspx?pid=2321&dl=1#bios
Not that you'll need it, but here's the general spec page for this mainboard:
http://www.gigabyte.com/products/product-page.aspx?pid=2321&dl=1#sp
Thanks!
Thanks!
