*UPDATE* Tried it again and it powered on, currently posting this from said PC... does that mean it's ok? Could it fail eventually in the future?
Please Help!
I took my mother board out to readjust my CPU cooler, I had it placed on the static free plastic that it came with the whole time. Once that was done I put it back in the case and plugged everything back in. It all looked good so I turned it on and immediately a HUGE spark came from the south side of the mother board, it looks like it was a little circuit just above the red IEEE 1394 hub with 8 prongs in it.
It looks like I plugged in the 8 prong USB 2.0 connector (for the ports on the front of the case) there instead of the blue one right beside it that it is supposed to go into (they are the same shape) :frown:
As soon as it sparked I pulled the power plug right away. There was some smoke and there is some residue/burn marks on the red IEEE 1394 hub.
Is my motherboard fried? What should I do? Try it again or is it definitely gone?
P5Q Pro/Q9550/Enermax Modu82+ 625W/2x2Gb G.Skill DDR2 1000/HD4870/Vendetta 2/200Gb HD/ XP SP3
Thanks so much!!
Please Help!
Thanks so much!!
