Help! Sound problem big time on SN45G
EstoyLoco
Anyways I just finished building my Shuttle XPC SN45G
I have it running on
Athlon XP 3000+
1GIG DDR333 Kingston HyperX DualDDR Matched pair
80gig Maxtor HD
PowerColor 9600 Pro video card
I have it hooked up using 6 channel to my Yamaha receiver.
Its volume range is: Off -100dB to 0 dB (highest volume)
I usually run it at -50dB on all my other setups, and it runs a perfect volume level.
Well I hooked it up via 6 channel analog inputs and I can't hear anything at all at -50, I have to chank the receiver up all the way to 0 dB to even hear anything, and even then its not very loud at all.
If I switch to Digital output, everything is fine.
It wouldn't bother me, if I was keeping this computer for myself as I have a digital input capable receiver. But I am building it for my little sister, who is going to be just using analog speakers.
Any help from Shuttle XPC owners or anyone who knows, would be greatly appreciated.
Thanks ahead of time.
Volume settings and the nVidia Soundstorm mixer are connected to each other.
They are turned all the way up on every single setting.
And it also affects digital output.
Is it possible that I might just have something defective in my XPC?
Btw it does the same thing for both the REAR and FRONT stereo mini plug outputs on the XPC.
Haha nevermind, problem solved...
I'm surprised the Shuttle drivers were crap.
I just updated to nForce drivers 2.42 and fixed the sound problem!
