I have a Sonata Case with Gigabyte GA-7nnxp, Athlon 3000+ running at 2.1 Ghz, 1 GB RAM and silent boost HS. I've got 4 HDD's and two CD-RW installed as well. I'm running two 120mm case fans as wellas the PS fans and still can't seem to get the CPU to run any cooler than 55-58 degrees. I even used silver thermal grease to attempt to help. My internal case temps are around 40 degrees C and the ambient room temp is 75 degrees F.
Any ideas?
Any ideas?
