HELP! Sometimes blank screen when power-up!!!!
Zero07
68
It doesn't happen too often, but when it happens it's just like the video card or the monitor is not detected.
My system:
AMD Athlon classic 700
AOpen AK72 mobo (KX133)
Elsa Erazor X² (GeForce 256)
SB Live 1024 player
Allied data modem
LAN
Antec PP303X psu
Anibus
131
Try re-seating the CPU. Also check the motherboard manual. Some require holding down a key (insert) while booting. Soyo motherboards sometimes require this.
ucdnam
1,059
I sometimes receive a blank screen if I overclock too much and the CPU can't handle it. This is on a p3v4x.
Fant
616
On my abit motherboard, I had to change the primary device to PCI rather than AGP (even though I'm using only an AGP video card) and after that video signal comes up every time.
Diesel21
203
I have the same problem on an Asus P2B. Sometimes my monitor is blank when I turn on my computer. It happens sometimes, but not too often but is very annoying!
Any help would be appreciated.
PS. I am using the latest bios for my motherboard and grapich adapter.
Kappo
2,381
Diesel21:
Try checking your bios and make sure either PCI or AGP (whichever one you have) is your video boot device.
If that doesnt work I have had to take the vid card out and reseat it before and actually bend the metal frame a tad to make sure it got all the way into the slot. It looks like it is all the way in but it isnt...those are the only two things I have tried as they have always worked for me. ;)
Mears
2,095
When you turn it back off and reboot after the screen is blank does it automatically go into the bios settings? If so I'd cut back a bit on the oc'ing.
Zero07
68
The system is not overclocked, and I'm using the latest bios and nvidia reference 5.33 drivers.
> Fant: I'm going to try that!
Thanks!
hungrypete
3,001
my A7V does that with any vid card I put in... gonna try fant's idea..... it's not that it won't boot, but whenever it's been sitting for awhile and i hit the power button, once in a while i get no vid signal; hit reset and everything is fine..... It's just kind of annoying.
Robor
Happens to me sometimes. I hold down the switch for 4 seconds and let it reboot. That usually solves it but sometimes I have to yank the power supply cord and reboot. It's only frustrating when I'm doing troubleshooting or loading an OS where a bunch of reboots are needed. I leave mine on 24/7 for SETI anyway so it's not a real big problem.
Rob
Zero07
68
I'm also suprised so many people have this problem. First I thought it was a Geforce-KX133 compability problem!
Anyway, I tried Fants solution, and it seems to work!
