- Feb 13, 2014
- 380
- 1
- 0
What would be better in terms of performance
2x 7970s in crossfire or 1 x 780ti
I think the 7970s , mate thinks a single 780ti
780 Ti vs 280x CF:
http://anandtech.com/bench/product/1072?vs=1058
Titan vs 7970 GHz CF:
http://anandtech.com/bench/product/764?vs=769
The 7970 and 780 Ti are technically from different marketing generations, which is why you don't see them compared directly.
The Crossfire rig gives higher FPS, but I'd personally take the 780 Ti or a 290X over the CF rig.
Are we talking GHz editions or standard 7970's?
The 7970Ghz edition and 280X listed above are the same card and are clocked significantly higher than the standard 7970.
It also depends on what game you are playing, Company of heroes 2 for instance favours AMD cards. Also you are not guaranteed full crossfire performance from every game so the 780TI would be more consistent.
Check this brand new review
http://www.ocaholic.ch/modules/smartsection/item.php?itemid=1300&lang=english
....Concluding it can be said, that under certain circumstances the two R9 280X cards are quicker than one GTX 780 Ti and they're also cheaper but if you want to invest your money in an as sustainable way as possible, then we'd recommend to buy a single card.
Crossfire on anything before 290/290x is beyond atrocious.
I would rate 2x 7970 as less than 1x 7970 in this comparison.
That's a lot of hyperbole.
