HELP!!! So my sound doesnt work on my PC anymore...
Mik3y
Banned
Mar 2, 2004
7,089
I just got a new case and I moved all my components into the new one and upon turning my computer on, everything works fine except that my audio has become a mute. I've tried onboard and the sound card listed in my sig. Tried reformatting and uninstalling and installing drivers and that doesnt work. If you guys can help me out here, that'd be really great. Thanks. I'm fresh out of ideas.
The Pentium Guy
4,327
Did you try the rear onboard sound or the front panel audio? Becuase you might have not hooked up the front properly.
Mik3y
Banned
Mar 2, 2004
7,089
of course. i'm not a nub. :D
ScrapSilicon
13,625
wassa nub ..? is that like n00b ?
anyway check in the mobo's bios for enable/disable switch ..afterall it is an ecs ;):p
Mik3y
Banned
Mar 2, 2004
7,089
already did. i know how to set it all up. this must be like my 20th pc build in the past 2 yrs. netiher onboard or the sound card works. u think my sound card coulda died during the move to the new case? my system reads it as functioning properly.
disperse
27
I would go on down the audio chain and check each link.
Is there a yellow exclaimation point next to the sound card in the System Manager?
Is the volume turned up and not muted in the Windows "Play Control" window?
Is the volume turned up and not muted in your software application?
Try a different pair of speakers or try headphones to make sure there isn't a problem with the speakers or cables.
These may seem like obvious troubleshooting steps but check them out. Usually the problem is something obvious that you overlooked.
Mark.
Mik3y
Banned
Mar 2, 2004
7,089
Mark.
already triple checked each of those and the problem still exists. :sigh;
Ike0069
4,276
Did you try it in different different PCI slots?
If so, sounds like you have a bad SC. Not really anything else left that could be the problem.
Mik3y
Banned
Mar 2, 2004
7,089
tried it already. still didnt work. how about my onboard sound then? that's not working either. i've already checked the cables and everything else also, and still no luck.
