Help? Small IIS5 question.
Ellhnas25
Banned
Ok i used IIS5 to make a web site. When I type localhost in my browser i can view it. But when i type my IP adress
a pop up window comes and asks me for my user name-password and domain name. I put the name I have from the Authentication window and my password but i get a 401 Authirization Request error.
When I type the mumber of my default gatway it asks me for my user name and password.
Can someone tell me how can i acess my web site with out using the localhost command?
There is a check box under IIS which allows you to enable guest access, which basically bypasses local authentication. I'm not in front of my computer now to tell you exactly where it is, but it's not hidden TOO deep.
Hmm the only thing i can find that has any relevance is a box asking about anonymous connections. I have checked "allow anonynous connections" and still same proble. Disable it and still same problems.
