hello guys
I just got a SLK 900 to use on my Epox 4pea+ motherboard. I am using the bolt down method for this heatsink but the hs is not making proper contact with the CPU. It seems like the black thingy that holds the hs is loose and makes the hs move a little.....
any clues on what to do ?
Thanks
Thanks
