HELP ! setup 2 wireless router on 1 ISP
zambi
Hello -
I am looking for some help from all the network gurus here. I want to setup 2 physically separate wireless router on 1 ISP router on my home network.
Following is what I am looking for.
ISP -> Cable Modem - > ????? - > Wireless Modem 1 (Main [MAC Access Controlled]) - > Laptops/NAS
\-> Wireless Modem 2 (Guest [Password Controlled]) - > Laptop
Also, I am not a networking person, so if I am asking for something stupid here please let me know.
If this is possible, please let how can I achieve this?
Thanks
It does sound like you want to set up two home subnets:
* LAN-1 for "home devices"
* LAN-2 for "guests", all wireless
Your ISP provides cable signal. There has to be a modem to convert cable signal into ethernet signal.
ISP has its own subnet. There has to be a router between two (or more) subnets.
ISP -- Cable Modem -- Router
A cheap all-in-one device can have both router and access point. It may further support more than one wireless subnets and be able to disallow routing between the two home subnets.
you need 3 routers for what you want to do unless you get a router which has guest wifi like TPLink Archer series.
But what you need to do is:
ISP -> Cable Modem -> Router -> Guest Wifi on / Guest WiFi Access Point / Wifi Router
-> Laptop / NAS on regular network though router.
You can get really complicated and go with a managed switch and setup VLAN and other stuff, but i think that is a bit too advance for you at the moment.
