- Oct 21, 2007
- 504
- 10
- 81
I have been running PCLinuxOS2007 as a live CD on an older box, P3 800MHz, 512 MB ram, with an Nvidia 5200 PCI video card. I needed to run the live CD in Safe mode with FB (frame buffer?).
It ran surprisingly well. I even got my Netgear wireless USB Adapter, WG111v2, working using the windows driver and NDIS wrapper. So I decided to install on my slave ATA drive, an 80GB WD drive. I used Wipe Drive to wipe the drive and installed. I used the auto allocate option and the OS set up boot, home and swap partions. Grub installs fine. I can select Windows XP from the bootloader and that
OS runs fine from the master HD. When I select Linux in Grub the OS will not load.I get the black screen( not the one with the red root icon) and am asked to log on and then for my password. logon and password are correct.
I get some error message.I thought it was my video card so I tried the intel integrated graphics
(its an 810 chipset board) same thing. I installed a Radeon 9250 PCI video card and I get the same thing. I popped in a live CD for Suse 9.2 and I get a screen that says I need to configure my XORG (?) with settings for my monitor, video card(dual head) etc. I could not quite get it figured out. I think this is my problem. How do I get to this screen so I can correctly configure this set up?
I have reinstalled the OS about 5 times, always the same thing. For what it is worth I got PCLinuxOS 2007 working in Virtualbox on my XP HD. Its sluggish as expected. I really want to run this OS. Help, suggestions & feedback desperately needed.
Please do not suggest I try Ubuntu. I
have tried 6.06, 7.04, 7.10 and XUbuntu. The live CD will not even run. This machine does not like Ubuntu or Ubuntu does not like it
Thank you in advance for any help you can offer.
