Help setting up sound with cs go
AutobotVu
I want to make counter strike come out my Sennheiser 3D G4ME1
and everything else come out from my speakers.
Another words I want to have music playing in the backround while playing cs instead of having to listen to both music and cs on headphones.
Windows 8
If your Sennheisser shows up in your playback devices (which it should after you install the drivers for it), this should work. Set your headphones as your Default Communications Device while your Default Audio device as your speakers. Then check in Counter Strike's Audio Settings if you can select a dedicated audio device (some games may have it and others may not).
36448d1391368454-split-two-different-audio-outputs-playback-devices-screenshot-2014-02-02-11.12.56.png
This youtube tutorial might also be helpful: http://www.youtube.com/watch?v=Vf5IdU9pTH8
Also read this: http://superuser.com/questions/329147/how-to-use-two-audio-devices-simultaneously-with-windows-7
