I have a netgear 1000wrn wireless router that I am trying to us as a wireless access point, but I'm having trouble.
The current setup is cbeyond internet going into a 16 port switch. All computers in the office are plugged into this switch. There is also a server that is providing DHCP.
Here is what I've done so far...
I first looked up the ip address on the server using ipconfig. It is set at 10.0.1.46. So I hooked the router up to one of the computers using the lan port. I then went into settings and disabled the DHCP on the router. I next tried to change the IP address to 10.0.1.199 but it said the address was invalid. I finally got that to work (there was a space in there that was messing things up). The router then reboots. It tries to reconnect to the router using the new IP address but it says that the page can not load. I also tried to connect using the address www.routerlogin.net but that doesn't work either.
So, I had to reset it to factory default and start again. Same result. I also tried setting the router to 192.168.0.199 and that didn't work either.
Another problem is that I'm tring to make a reservation for this address in the DHCP settings on the server, but I am getting an error that it is an invalid address.
Any help would be greatly appreciated.
