from MSI website-
 	 Right after booting off of the Windows cd, you need to push the F6 key when prompted (Fig-a)
? 	Next when prompted (Fig-b) install the correct driver from the floppy disk provided with the motherboard, press the S key to specify the driver, and select the correct driver depending on which controller you are using, then press enter key to continue.
? 	After this Windows 2000/XP will continue the installation, and will detect the S-ATA hard drive to be installed onto.
But I dont have floppy, so what can i do? Slip Stream install? I dont know how to do this, if anyone can help
