- Sep 13, 2000
- 11
- 0
- 0
Alright I just got an CUSL2 @ p3 700e (cb0) and I have one stick of CAS 2 certified mushkin pc133
I was wondering if you guys could give me some bios settings, like what I should set the memory timings to. Also what voltage should I not exceed? I plan to try to get this baby to ~1ghz which brings me to my next question:
I was going to put my peltier's cold plate directly on the CPU however I am concerned about condensation even though im using really tight foam surrounds. I have heard of people mounting a heatsink directly on the CPU, then putting the peltier on the heatsink, does this work? I should also mention I have a copper watter jacket all setup from my old computer that I will be adding to this one. Are there any other ways to effectivly mount everything other this the way I had planned:
cpu--> coldplate --> peltier --> waterjacket
Thanks in advance,
~Arctic
Thanks in advance,
~Arctic
