Digita1Zombie
Hi, I am new to water cooling and am currently building my first water cooled rig. I would like some feedback on my components and whether or not to split my loop with a Y. I have a swiftech mcw5002 block w/ peltier 1/2 inch inlets and a swiftech NB chipset block 3/8 inlets, i also have a double 80mm Dual pass rad w/ 1/2 inlets and a single 80mm dual pass rad w/ 3/8 inlets. I have adapted the block for LGA 775 and plan on installing on a QX6850 in an abit P35 Pro mb. I want to keep this first build as simple as possible. If I can get away with just the cpu block and double 80mm rad w/ just 1/2 tubing that would be great. But if I need the extra rad or chipset block, should you use a Y and keep the 1/2 inch and 3/8 components together on 2 smaller loops with a Y on the single swiftech pump? I'm new to this forum, if this post is in the wrong section, please inform me and thanks for any help!
