help setting up iptables
RichieZ
Ok so I want to block bittorrent, or at least the most common ports 6881-6889
I'm using a Linksys WRT54GS V2.0 w/ Sveasoft Alchemy RC5a
lets say I justed wanted to block port 6881, wouldn't that be:
nvram set rc_firewall='/usr/sbin/iptables -I INPUT -p tcp -s 192.168.1.1/199 --dport 6881 -j DROP'
nvram commit
and then reboot?
But when I check iptables -L -n it doesn't seem to show up
Please help
Make sure iptables are located in /usr/sbin, not /sbin (run 'which iptables')
Your /199 is invalid, you problably need /24 (for 1.x subnet)
Also you should probably use FORWARD, not INPUT
hmm reading up it seems I should be using the FORWARD chain since this is on my router.
I'm not sure about the syntax tho
$iptables -A FORWARD -p tcp -s 192.168.1.1/24 --dport 6881 -j DROP
How can I set it up to block both imcoming and outgoing connections on port 6881?
Both incoming and outgoing packets pass FORWARD, but obviously for incoming traffic you should match by destination:
... -d 192.168.1.1/24..., for outgoing -s 192.168.... (like you use now).
