help setting up internet connection after flashing to dd-wrt
E6700
i've sucessfully flashed my WRT160N v3 to dd-wrt today but dont know how to setup internet conection afterward,can someone give me some advice,thanks alot.
You need to provide alot more information if you want help. After flashing - the DDWRT defaults to DHCP on the WAN side - if your ISP supports this internet will be automatic. You just need to setup the WAN of the router based on your ISP. If your on DSL that uses PPPOE - you'll need to set this up on your router just as you would any router. There's nothing different about DDWRT compared to other routers with respect to the internet setup. If your on cable, I'd suggest power cycling your cable modem then restarting your router.
