Help Selecting Graphics Card
sstterry
7
Could you give me recomendations on a good mid-range Graphics Card (ie. $150 or so). I don't do too much gaming (some but not a whole lot). I was hoping to start some video editing and burning home movies to DVD. A friend has recomended the ASUS v9520vs. but it is based on the FX 5200. I think I would like to have something a little better.
Sorry, I haven't kept up with the Graphics Card Market in a Couple of years and I am totally lost. Any reccomendations would be appreciated.
sstterry
7
Thanks. Would the Fx 5600 be a better choice? I'll be running a 2.4 p4. with 512 DDR Ram.
Schadenfroh
38,416
4
no, a 5600 non ultra is slower than a 4200 and a 5600 ultra is in 9700 price territory
Soulkeeper
6,740
156
i got a ti4200 it is great
only problem with getting one might be lack of support for dx9 but if yur not playing the latest games next year then you got nothing to worry about
IQJUMPuw
761
If you are looking to spend around $150, I suggest GF4 Ti4200 128MB AGP8X or ATi Radeon 9600 Pro. 9600 Pro costs more, but it will be much faster than Ti4200.
Pete
4,953
Take a look into a ~$165 128MB Radeon 9600 Pro as well. A ~$100 64MB 4200 is probably a better price/performer for the average gamer, but a 9600P will be faster (much more so with AA &/ AF), will probably have better signal quality (sharper, thus more legible, text) at desktop resolutions higher than 1024x768, and will probably have better-looking DVD playback. The last two features are common across all ATi Radeons, but the main reason a 9600P is more expensive than a 4200 is because it's faster (without and especially with AA+AF) and more future-proof (DirectX 9 vs. 8).
A 9600P is also faster than a 4800SE, so unless you need the VIVO feature pretty much unique to nVidia cards at the moment, you're better off with a 9600P at that price point, IMO.
I think a ~$165 128MB 9600P is a wiser purchase than a ~$120 128MB 4200 at this point. Still, you may not value the extra speed and potentially better signal quality a 9600P will afford you over a comparable 4200, so a 30=50% cheaper and less-equipped (likely only VGA output, no DVI or TV or dualhead) 64MB 4200 may be a smarter move.
Edit: Though, really, depending on what games you play (Sims/Tropico or Unreal Tournament?), you may be satisfied with a Radeon 9100 or 9000 Pro. Neither will be faster than a 4200 at plain rendering, but a 9100/9000P will pull roughly even with a 4200 once you enable AF. The 9100/9000P will also have better-looking DVD playback a probably have better signal quality. You should be able to pick one up for $60-80. 9000P's are all 275/275MHz core/memory, but not all 9100's are 250/250MHz (only Visiontek has all their 9100's clocked at full speed, while Sapphier and Powercolor and other manufacturers have varying speeds for various versions), so it may be easier to just look for a 9000P then have to confirm that the 9100 you want is full-speed.
