Help Selecting CPU/MB with my new desktop build
lovespicyfoods
Hello Everyone!
Long time reader, first time poster! 😉 Well...actually I posted quite a few years back and I'm trying to resurrect that username, but I digress...
I've just recently started to do research on a desktop build. I'm in somewhat of a hurry because I'm starting a new full time job next week and I'm starting part time business school in early March.
1. What YOUR PC will be used for.
I'm not a gamer, but I do like the occasional game. I'm addicted to radio control helicopters and I would like to use my software (RealFlight 4) at the highest resolutions. I currently have it setup at medium settings and it works alright on my old AMD Athlon 2.5ghz w/ 2gb of ram.
I'm also into digital photography, but the current system seems to run okay w/ Photoshop CS.
My buddy is purchasing me MSOFFICE 2007 and I plan on using it a lot for business school.
I almost forgot, I just purchased the upgrade Windows Vista Home Premium for $99. I figured I'd give it a try from XP...
2. What YOUR budget is.
I've already spent ~$600 for hardware and software (Office '07 and Vista). This is including the MIR's that I have yet to fill. I'm thinking another ~$300...
3. What country YOU will be buying YOUR parts from.
U.S.
4. IF YOU have a brand preference.
NONE
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
Yes, a 21" Dell widescreen, standard CDRW drive, standard DVDR drive, basic speakers for now
6. IF YOU have searched and/or read similar threads.
Yes, I was going to go w/ a Fry's mobo of an AMD Phenom 9500 and ECS mb for $219, but reading some info on here scared me off...
7. IF YOU plan on overclocking or run the system at default speeds.
No, but if it's easy, I might bump it up a little. Since this will be a school computer, stability is my primary concern
This is what I've purchased so far:
Antec P182 Case (~$70 after MIR)
Antec NeoHE 500W ($59.99 at Fry's)
4gb (2X2gb) Aodata DDR2 800 ($75 at Fry's)
XFX GeForce 8600GT 256MB GDDR3 vid card (~$85 after MIR)
500gb sata-2 hd (I forget which brand, I think Seagate) ($99 at Fry's)
As I mentioned up above, I was going to get the AMD Phenom 9500 and ECS mb for $219, but reading these forums, I'm a bit scared. Now I see the Intel Q6600 is highly regarded, but I see it's $275 for the cpu and I would still need to get a mb.
I realize that given my needs, I'm probably looking at too expensive/fast of a processor, but I figure I might as well build it as fast as I can given my budget.
This all being said, if I were to go with the Q6600, what economical mb would you suggest? Currently, Fry's doesn't have it on sale so I'd probably buy it at Newegg. I forgot to mention that I do not have a sound card, so the mb should have that. Or I could put a cheap card in, but I'm not a big sound afficionado.
I'm thinking some people would suggest the Core Duo's, but to me, it's quite confusing. I do know Fry's has a lot of the "E" chips on sale regularly. In fact, I'm looking at the latest ad and they have E6750 with ECS G311T-M mb for $199. Looks like it has built in video (YUCK) but an PCI-E 16X upgrade slot. From my past experience, it seems that when things are on sale at Fry's for mobos, basically the mb is free in the purchase price. I know ECS isn't a GREAT mb usually, but considering my needs, I think it will work.
Any and all advice is much appreciated! Feel free to tell me I've blown my current purchases, I'll understand! 😀 I'm actually somewhat regretting my vid card choice... I wonder if I should have spent more $ on something else, but oh well...
THANKS IN ADVANCE!!!!!
Pete
Gigabyte DS3L or ABIT IP35-e + e2180 or e4500. You really don't need a q6600. http://www.newegg.com/Product/...x?Item=N82E16819116052 for e2180 + abit ip35-e http://www.newegg.com/Product/...7031&Tpk=abit%2bip35-e For a total of 140-150$ !!!
Or, http://www.newegg.com/Product/...x?Item=N82E16819115031 e4500 + DS3L http://www.newegg.com/Product/...2E16813128059&Tpk=ds3l or just go with the abit ip35-e. Either 185$ or 215$. Way below budget, and both can be overclocked to 3.0ghz without any real trouble.
Thank you SO MUCH for taking the time to point me in the right direction!
I'm going to wait to see the Fry's ad that usually comes out Fridays to see what they have on sale.
So the AMD Phenom 9500 at $219 is not advised and slower?
