System Specifications:
I. Processor/CPU: i5 2500k
II. Current Graphics Card: N/A. This is for a new build.
III. Display Resolution: Currently 1440 x 900. Planning to upgrade in a few months.
IV. Power Supply Unit Specification (Brand, Wattage, Ampage, Age). If possible, please provide a link to a website containing the power supply specifications: Have not selected a PSU yet, waiting to see what the rest of my build looks like
V. Case Specifications(N/A, Model, Length, Low Profile, Cooling, HTPC, Water, Silent):
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119233&Tpk=haf 912
Purchase Details:
I. Budget? Please be sure to include currency (If not USD), retailer preferences & specify whether rebates are a viable option.
For the card, I would be willing to spend $250-$290.
II. Any particular preferences (Manufacturer[nV or AMD], Brand[XFX, Sapphire, EVGA, etc], Cooling Solutions)?
No preferences.
III. Do you plan to have any Multi-GPU solutions such as Crossfire or SLI?
Not planning on it.
IV. Have you previously looked at a product(s) which you feel would fit your needs?
Yes.
V. What are your needs for this GPU? Which games(If any)do you intend to play? If you have this information at hand, what are the desired detail levels?
This will be for gaming. No specific games at the moment, but if I could play everything out at the moment at max settings, that would be wonderful. Something that should hold up to industry standards for awhile, though I understand that industry standards change rapidly.
VI. Do you plan on overclocking the card you intend to purchase?
Not planning to overclock the GPU.
Additional Notes
I've looked at the two cards below, as starting points, anyhow.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127608
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121480
The space requirements for the ASUS card worry me. It's a big one. I'm not sure how marked the difference between stream processor cores is whilst gaming, or how it will actually manifest itself.
Those two cards are just potential ones that seemed like a good fit, not dead-set on either. I know nVidia will be releasing new cards in April, I would prefer not to wait, but if it really makes a ton of sense to wait, I suppose I can.
Please, any suggestions would be very helpful. I hope the fact that I haven't selected a motherboard yet doesn't make this whole request a dumb one.
Purchase Details:
No preferences.
Not planning on it.
Yes.
Additional Notes
