Hey there folks,
I recienty purchased a scsi setup and this was my first dip into the scsi world. I bought a Adaptec AAA-131U2 scsi Raid controller and two Seagate ST118202LC using this 80-68 pin adaptor. Here is the seagate website for my drives but it is fairly bland. Now I will explain exactly what the error is I am getting and what happens after than and what I have done to trouble shoot this.
Here are the errors I am getting. mide you I am at work and this is for my personal PC so I have written down all the errors in my effort to be exact as possible
When I boot my computer to does POST then goes to the SCSI bios screen. it says press (F6) for setup. Next it says 64M memory check is good then next it goes to detecting the drive. it says "Ch A, SCSI ID #1: Start Unit Request Failed". so I reboot an dthis time hit F6 to enter setup. there are two options, one is for settings and the other is what is in the scsi chain. so I select the latter and it cycles through the scsi ID numbers 0 - 15 and then displays a list of ID's and whats on each ID. I says on ID 1 my ST118202LC and I can select two options from there. 1 is to do a low level format and the other is to verify drive intregety or something to that effect. I click on the veruify option and I get this error.
____________________________________________________________________________________________________
SCSI CDB Sent: 03 00 00 00 0E 00 07 00 01 00
Host Adaptor Ststus: 00h - No Adaptor Error
Target Status: 02h - Check Condition
Sense Key: 01h - Recovered Error
+Sense Code: 5Dh
+Sense Code Qualifier: 32h
so now I hit esc and then select the same option again and it asks if I would like to verify the drive and I click yes and it does it's thing and says it's fine. wtf?
ok so I do have two of these and it seems to only be one drive but sometimes it's there and something it's not. so I switched SCSI ID's and 80-68pin adaptors and some thing. NOW it's erroring everytime. solo
here is another catch, when I add two drives and the drive with the lower SCSI ID errors this time requardless of the drive I use but when I test them seperately I get the error on that one drive repeadately.
Now here is what agervates the mess out of me, I can install an OS on the errored drive and it works fine. I can also build an RAID 0 array with it and it works fine too. When I use the array config utility is shows no problem with that drive .
here is how I have my setup
___
[___]-----|-----|-----|-----|-----|-----|-|
toi the left is my HBA and then the 7 slot cable with my terminator at the end. notice how the two slots ad the end are very close? one is facing one way and one is facing the other. This seems to be where the cable was designed to host the Active Terminator and I place my two drives in the two slots closest to the terminator with scsi ID's 0 (being right next to the terminator) and 1 (being next in the string). From what I have read this is right and should be right.
here is my last option. I can buy a matching drive w/o the PCB to replace my errored drive and I can switch my PCB off thatr drive and use the new one. (does that make sense?) will that help or do you think my prob is somewhere else.
Thanks to all who read this and provide insight.
Mitch
EDIT 1: I just d/l Seagates SeaTool and I am going home for lunch now to try it. I will report my observations when I return.
EDIT 2: I finished the 100% short test and the Long test both with Good condition rating. it says there is nothing wrong with the drive. now i am confused? could be a bad cable? (it's brand new) or the card is going bad? I also moved the cards around and moved the scsi card to the top slot minus 1 for space between video and scsi then there is a space below the card then my nic and the Audigy.
here are the SeaTool results
here they are.
I am assuming this is the good drive with scsi ID 0
sh-2.05b# ./st -i /dev/sda
/dev/sda
Vendor = SEAGATE
Product = SX118202LC
Version = B701
Serial Number = LK031099
Copyright = Copyright (c) 1998 Seagate All rights reserved
SCSI Firmware = 0528B701
Servo RAM Release = A128A128
Servo ROM Release = A128A128
Servo RAM Date = A128
Servo ROM Date = A128
Blocksize = 512, Highblock = 35566479, Capacity = 17783 MB
-this is a Seagate drive
-this drive does not support DST
-Mode Page Settings [current value (default)]:
-WCE bit = 1 (0)
-RCD bit = 0 (0)
-AWRE bit = 0 (0)
-ARRE bit = 0 (0)
-DExcpt bit = 0 (0)
-Number of cache segments = 16 (16)
-JIT bit 0 = 0 (0)
-JIT bit 1 = 0 (0)
-JIT bit 2 = 0 (0)
-JIT bit 3 = 0 (0)
now this is from the drive that gives me errors
sh-2.05b# ./st -i /dev/sdb
/dev/sdb
Vendor = SEAGATE
Version = B70C
Serial Number = LK539676
Copyright = Copyright (c) 2001 Seagate All rights reserved
SCSI Firmware = 0223B70C
Servo RAM Release = A129A129
Servo ROM Release = A129A129
Servo RAM Date = A129
Servo ROM Date = A129
-WCE bit = 1 (0)
-RCD bit = 0 (0)
-AWRE bit = 0 (0)
-ARRE bit = 0 (0)
-DExcpt bit = 0 (0)
-JIT bit 0 = 0 (0)
-JIT bit 1 = 0 (0)
-JIT bit 2 = 0 (0)
-JIT bit 3 = 0 (0)
crapola
+Sense Code: 5Dh
___
Mitch
here they are.
/dev/sda
Vendor = SEAGATE
Version = B701
-WCE bit = 1 (0)
-RCD bit = 0 (0)
-AWRE bit = 0 (0)
-ARRE bit = 0 (0)
-DExcpt bit = 0 (0)
-JIT bit 0 = 0 (0)
-JIT bit 1 = 0 (0)
-JIT bit 2 = 0 (0)
-JIT bit 3 = 0 (0)
/dev/sdb
Vendor = SEAGATE
Version = B70C
-WCE bit = 1 (0)
-RCD bit = 0 (0)
-AWRE bit = 0 (0)
-ARRE bit = 0 (0)
-DExcpt bit = 0 (0)
-JIT bit 0 = 0 (0)
-JIT bit 1 = 0 (0)
-JIT bit 2 = 0 (0)
-JIT bit 3 = 0 (0)
crapola
