HELP: Screw my WinXP
pecel
Hi All,
I did some tweak that I read on TweakXP
After I restart my comp, my Norton Anti Virus won't start.
It show on the task bar, but it's disabled. 🙁
Usually it start and directly enable for auto protect.
I already saw/set the option for NAV, it say auto-protect enabled on startup and start when windows start up.
Any Idea what should I do to turn it on again?
Thanks.
Click "start", go to "run" and type in "msconfig" (without quotes) and under the "Startup" tab, see if your norton is unchecked. With tweakXP, you may have set items that normally started up at startup to not startup. If that doesn't do the trick, open NAV and look under prefferences for anything that may disable it at startup.
i accidently disabled norton in the startup menu once . after re-enabling it , it never would start by it's self again.
had to reinstall it .
good luck
