There is a workgroup called "WorkGroup" in the entire network. The computer name I see is Swlsb. How can I make sure they don't have access to ANYTHING?
How did they get there? What can I do to them?
Thanks.
Edit: It was a computer I was fixing for a friend.
WORKGROUP is the default workgroup name when a computer joins a network. Each machine has a Computer Name and a Workgroup in which it belongs. Depending on the OS... check the network properties of each machine and you'll find Swlsb.
What do you mean make sure they don't have access to anything? How does the web server fit into this scenario?
