HELP! Running a 650 Athlon w/Giga-byte GA-7IX and my agp is only going 1x.
Trader05
This is an Athlon 650mhz setup. I don't know why, but for somereason i am only getting 1x agp. Using an Asus Geforce2 GTS 64mb card. Is there a bios setting, cause i looked and didn't find anything that said that.....or a jumper? The board susposed to go to 2x agp. Does anyone know what's the problem?
This may or may not help. I use VIA apollo pro 133a chipset boards for my PIII's. When installing the VIA 4 in 1 drivers (or just the VIA video driver) on 133a boards, you must install them in 'turbo' mode to get the AGP 4X to work. I'm not sure if the KT (KZ or whatever the VIA athalon chipset is) has this same requirement.
